Incoming calls
  • 19 May 2015
  • 7 replies
  • 225 views
on the $33 monthly plan, are incoming calls part of the 300 minutes allowed or are all incoming calls free?
All incoming are free unless they come from outside Canada. Then they use your minutes I believe.
All incoming are free unless they come from outside Canada. Then they use your minutes I believe. Thanks. Appreciate your help. Have a great day!
All incoming are free unless they come from outside Canada. Then they use your minutes I believe. You as well.
Unfortunately that is false, Incoming and Outgoing both take your airtime. The only way it doesnt is if it specifies on the plan Free Incoming Calls, this is only on some very old plans. However, you are not charged for incoming Long Distance.
Unfortunately that is false, Incoming and Outgoing both take your airtime. The only way it doesnt...All incoming calls gobble regular plan minutes, [i]regardless of their origin. The only way to get "free" incoming or outgoing is to buy the appropriate "unlimited" add-on. Long distance will apply to all [i]OUTGOING calls that fall out of your normal calling zone.
Unfortunately that is false, Incoming and Outgoing both take your airtime. The only way it doesnt...Thanks for the clarification! Can't believe I didn't know that.
With the 33$ plan you do receive unlimited calls during evenings and weekends but any calls (incoming/outgoing) made during weekdays will be deducted from your 300 minutes.
