if i upgrade phone can keep my existing add on?
  • 6 September 2019
  • 98 views
if i upgrade phone with tab small, can keep my existing add on?
@Loyal Customer 101 If you simply just purchasing a new phone on Tab small that shouldn't affect your add-ons.
Do you mean your plan or add-on?
https://www.koodomobile.com/help/keeping-or-changing-your-plan-when-you-upgrade-your-phone
HI Dennis, my existing plan is $40, I think tab small will be transferable. I am worry about add on and bonus data to the new tab small contract
If your plan doesnt change then your add-ons and bonuses will remain as per the previous arrangement
@Loyal Customer 101 You need not to worry since you are not changing plans.
