i keep getting an error when i press get a new phone, help!
  • 18 July 2020
  • 8 replies
  • 161 views
I need help, I keep getting an error logging in and it logs me out.
Was it working before?  When was last time you logged in?
I can access my account but when I add a phone to the cart and go to check out, the screen appears to say add a new line or get a new phone and I press get a new phone it loads and then the errors appears. When I press add a new line it loads normally
Did you try to clear the browsing history or use different browsers?
Yes I have tried 2 browsers on my phone and 2 on my laptop and it keeps giving me the same error
I'll Flagg this.
You can also send them message through FB or Twitter. They can check your self serve/ account and help you fix this issue.
Hi! You can send us a private message on Facebook https://m.me/Koodo, so we can look into this further. Thank you.
It's been down for a few days. I'm surprised no one has solved this.
There’s people having the same issue here :https://community.koodomobile.com/billing-66726/buying-a-new-phone-7799018
