I have three phones and one phone needs more Data how do I get it ..omg it's costing me big bucks the way it is.. Pls need help fast
Userlevel 4
That one phone would need to change its plan. You can use Self Serve or call Koodo. Using Self Serve is free to change while calling Koodo would charge you $10 to change the plan.
thank you so much..Will do this now
