i am upgrading my phone can i keep the same plan i am on now
You most certainly can! Unless you're going on tab L (which i do not recommend) you will need a tabL plan. also if you're going on tab M your plan has to be at least $29 in order to keep it.
Daniel Kim wrote:
You most certainly can! Unless you're going on tab L (which i do not recommend) you will need a t...
Lol sorry... I typed too slow 😛
there's nothing to be sorry about Sophia 😃
Oh yes, definitely 🙂 What plan are you on right now? Anything over $30 will qualify your for the Tab Medium, you can always get Tab Small no matter what plan you have though 🙂
Thank you for your help i am going to stay on small tab to keep my current plan
