How tabs work
  • 22 September 2018
  • 4 replies
  • 89 views
I was wondering if my understanding of how the tab system works at Koodo is correct. If I was to get the Extra Large Tab for example the monthly payment would be 75$ then drop to 45$ after 24 months? Someone tried telling me that it would be 75$+30$ a month but that doesn't match anything I've seen on the website yet but I figured I would ask and find out.
Also another question I had was what was meant by "Shock free data"? or is it just a marketing thing?
Thank you for your time.
Best answer by Dinh 22 September 2018, 21:28
@Poltr
Hi,
The official explaination of the Tab from Koodo is here: https://www.koodomobile.com/tab
Koodo separated rateplan and Tab. Extra large Tab requires a plan of $75 or more. On top of it, you would have to pay $30 /m (24 months). so $75 (or more) + $30 per month...
you could find out about Koodo shock free here https://www.koodomobile.com/datacalculator
They paused your data consumption when you reach the limit. You need to authorize for the data overage, if you would like.
@Poltr
Hi,
To get an extra large tab the minimum monthly plan has to be $75 a month. Plus the $30 tab for 24 months.
Shock free data means you can't go over your data without getting a warning to acknowledge.
Ahh okay. thank you for your replies. @Dinh @Mats
I suggest against getting the tab extra large. Those plans cost 25 dollars a month more for the same data as an equivalent tab medium plan.
