How much am I charged per incoming call if I don't get "unlimited"?
If I go for a plan that doesn't have unlimited incoming calls... 1. Am I just limited to the amount of incoming calls per month? or, 2. do I pay for each incoming call and if so, how much?
Best answer by Reena 23 March 2013, 18:07
Hi Lyndsay You will be using your airtime minutes. If you go over your airtimes minutes in your billing period then the overage charges are 45 cents per minute.
1 reply
