how do you text add on for roaming
how do I text the add on roaming to USA cant figure it out
Hello Brandon. What don't you understand? How can we help you because it looks quite simple : To activate: Text 3TXT to 4545 or something else depending on your roaming package
Are you currently in the US? Texting add-ons only work while in Canada.
Hey Brandon! Were you able to add the add-on?  If you're not able to through text, try adding it on from your self-serve account 🙂
