How do you add phone card booster to automatic top up base plan
I've registered for automatic top ups using my credit card but when I bought the phone I also bought a $25.00 worth anytime minutes. I can't seem to find out where I can enter the PIN number for the $25.00 anytime minutes in the self serve site. Is there any way of adding the booster using the phone card rather than having it charged to my credit card.
Hi David, You can add that voucher when you click "Top up your account" and then select "Top-up voucher". If you have automatic top-ups enabled as well, you can use that $25 to get the minutes booster and your credit card will be used to renew your base plan 🙂
Thanks Sophia. Worked like a charm. Have a great New Year.
