How do we use Call Forwarding Variable?
In response to Billy Munro on Facebook: http://www.facebook.com/permalink.php?story_fbid=10152333129718102&id=14750623101 Could someone please explain the proper format for using "Call Forwarding Variable"? I see the instructions on Koodo's page, but it's giving me grief. Thanks.
Just to be sure, you have it as part of your Plan / Add-ons, correct? If not, it needs to be otherwise that might be the reason you're having a problem setting it up. I had problems too until I added it to my account. It use to be included on older Plans but then got removed on newer Plans so you'll need to add it to your account for 3$/month https://shop.koodomobile.com/plans/add-ons/index.html
Userlevel 2
The addon doesn't control whether it works. It only removes the pay per use rate.
