how do i turn off CALL FORWARDING when outside of Canada and the phone is off... with out using the phone?
Call Forwarding, how to Question
To my knowledge, call forwarding can only be done from the phone.
You can message Koodo via Facebook messuand ask them to do it however since this is something you could do yourself, they may charge you. Is there some reason you can't do this from your phone?
I am in the states and i tried it and does not work from here...
Looking for a plan "B" to turn, Call Forwarding Off...
Have you tried the suggestion above to contact Koodo via Facebook messenger?
http://M.me/koodo
Wat wrote:
Suspend the line using Self Serve, leave voicemail active. Free.
Voicemail is disabled when you suspend your line.
I confused seasonal hold with suspend. My bad.
AFAIK, access to voicemail means that you can call in from another phone and retrieve your existing messages. The line, incoming and outgoing, is dead.
