how do i block a number on my koodo wireless home phone UL service?
  • 7 January 2021
  • 1 reply
  • 391 views
i keep receiving a fraudulent call that says it’s from TELUS but i checked with them and they say they haven’t been calling. whoever it is hangs up right away so i’m pretty sure it’s not TELUS. anyways, i’d like to block the number. any ideas?
Best answer by Dinh 7 January 2021, 21:25
1 reply
You could use the feature “call control” to block that number https://www.koodomobile.com/en/help/call-control
You would need to add the “$0 Call control” add-on in self-serve then use the Self-Serve » Mobile Service » Call Control.
