Help with add-ons
Am I allowed to just change how much data I want. I only have 250 MB and I want more....
Hi there Lisa... By now, there are no add-ons for additional data, You have 2 options: You pay the over usage rate (Based on the plan you have), or you upgrade your plan to one with more data included... Check the plans, and check what fits your needs!
Data is part of the plan, so if you wanted more you would have to step up to the next size up rate plan. There are a lot of options, it just depends on how much data you want/need.
Okay, thanks you guys 🙂
You may want to look into the prepaid offerings. Data and Talk Boosters don't expired as long as you keep renewing your base plan.
