Help, oh wise ones! $75 US add-on - can't keep track!
  • 16 June 2015
  • 4 replies
  • 25 views
I live in Ontario, Canada, have an iPhone 5, and will be traveling in the U.S. for 3 weeks. I purchased the $75 add-on for 750 mb of data, and unlimited calling and texting. Is there somewhere I can keep track of my use, as the usage page doesn't mention the add-on? Thanks!
I've passed your question to the powers above. Hopefully, we'll hear back soon.
You can reset the data on your phone in Settings > Cellular> Reset statistics. Then you can keep an eye on the consumption there. While it may not be exact, it should be fairly close!
Thank you for that!
We're still waiting for a definite answer, Iyit Jwik, but so far the most official word we could get was "there is no real time info passed from our roaming carrier partners that we could serve up customers. The delay varies based on carrier partner, locations etc. Until real time is passing of info is figured out third party apps remain the best choice." So it seems dfbutt was right on the ball with that one 🙂
