HELP - Is it too good to be true?
Is the Lightweight Canada-wide $39 a better deal than my old plan "The Works" which I got back in 2012? It looks like I'd be getting double minutes and 50mb more data for a dollar less per month! It looks better on the surface, but I'm no expert and I want to make sure I'm not losing out on anything that I currently have! Thanks 🙂
You would be getting a better plan for a $1 cheaper 🙂 I would reccomend changing it 😃
Thanks for the recommendation! Seems dumb, but I felt I needed a second opinion!
It's overall better indeed. I think the data overage might have been better on The Works plan but I can't recall what it was.
I never go over, so it sounds like a done deal! Thanks guys
