Going to Cancun and will be choosing the text add-on. Will it work in Cancun?
Which text add-on are you talking about? If you chose the Mexico one, then yes it should work. Make sure you add intl romaing too to your add-on from Self Serve!
Userlevel 3
Hello Elizabeth,
Robert is right. You can find the detalis about the Mexico and Carribean add-ons here http://koo.do/L0AUYo by choosing  "Travelling to Mexico or the Carribean". You will need to add the international roaming option only if you choose to go with the pay-per-use rates.
Thank you!
