getting double minutes without changing current plan
hi, I m using canada wide talk and text 35 plan for 5 months. i get 200 minutes in this plan. but I want to ask that cant I get 400 minutes according to your recent update of this plan
You have to change to the new version to get the double minutes.
sry , I didnt understand. Wht do u mean by new version?
You need to go in self-service, mani, and upgrade your plan manually. You won't automatically get the double minutes, you will need to change your plan (to the plan with the same price, but double everything)... it's free and then you can enjoy the double minutes and data forever 😃
Hi Mani, Plan updates does not automatically change your plan, you will still have to change plan by going to your self serve. Hope this simplifies it 🙂
