Double Credit Card Charge After Change of Plan
  • 17 September 2020
  • 2 replies
  • 52 views
I changed my plan on Sep 17.  It is also the date my plan was to be renewed automatically for the next month.
Now I see that I have two charges.  How can I get that fixed?
Thanks for your help.
Best answer by Dennis 17 September 2020, 22:03
You may send a private message to Koodo via Facebook messenger or dm via Twitter with the details and ask them to fix the double charge.
I assume you are post paid?
When this happens your bill should provide a credit for the part of the plan you did not use when the new plan is added.  When you download your detailed pdf ebill, do you see this?
