double
  • 5 March 2013
  • 1 reply
  • 1 view
If i sign up for the double plan and stay with you guy for 2 years. Is that plan stay in effect for all two years?
Best answer by Ahmad 5 March 2013, 22:01
You will be able to keep the same plan until you change your plan or cancel. So the answer is yes. As long as you keep it, it won't go away and Koodo won't force you off it
1 reply
