does Koodo have a roaming agreement with Maritime Communications Partner AS for cell access onboard Princess Cruises?
  • 10 January 2015
  • 1 reply
  • 425 views
I need access onboard Princess Cruise Lines. Their cell provider is Maritime Communications Partner AS. Does Koodo have a roaming agreement with them so that I can use an Add-On?
Best answer by BobTheElectrician 10 January 2015, 21:38
Cruise ship rates are generally of the satellite type since there are no towers out at sea. Count on $7 a minute according to Koodo's international scale. If you are cruising the Caribbean, you may be OK with the Mexico/Caribbean plan while you are ashore. I don't see Maritime as a listed partner in the nearby country list. You might be better to ask Koodo directly about this, not this usergroup, since it could be an expensive misunderstanding. http://help.koodomobile.com/coverage-long-distance-and-travelling/travelling
1 reply
