Difference betwen $60 and $72 plan
In the latest plans released today, what is the difference between "UNLIMITED Unlimited Incoming" ($60) and just "UNLIMITED" ($72)? Are they not the same thing?
Userlevel 4
0.5gb extra data apparently... The overage rate of the $60 is better and it is currently on the the double promo still. Once the promo is over, it will make more sense for the price difference
I understand the data difference. I'm just wondering about the calling plan portion. Shouldn't the $60 plan just say "UNLIMITED" rather than "UNLIMITED Unlimited Incoming"? The way it is written makes it sound like there is a difference between the $60 and $72 plan.
Userlevel 4
Darren Martell wrote:
I understand the data difference. I'm just wondering about the calling plan portion. Shouldn't ...
In that case, uneccessary additional words.
Maybe it means UNLIMITED calling, and UNLIMITED INCOMING calling?
Userlevel 4
Both are one and the same
Not nessicarily Zaphod. In this case it looks like a typo. But Unlimited calling, and Unlimited INCOMING calling are two different things. One means all calls (in and out) are unlimited, and the other implies only calls coming to you are unlimited.
Userlevel 4
I get what you're saying but using logic for a moment here, if there are no minutes posted and instead it shows "unlimited calling," would that not be a correct implication that incoming is included?
I think it may be a typo. I will let our Koodo contact know
Userlevel 4
My other speculation is they added that to the new plans so people will stop asking "my plan has unlimited calling. Does that include unlimited incoming?"
Userlevel 3
Also there seems to be a $5 charge to use tab medium on the $29 plan but I thought you need to have a $30 or higher plan to use tab medium. I don't see this restriction when I look at the fine print via the link with tab medium. Has this detail changed?
Userlevel 4
Moonmack wrote:
Also there seems to be a $5 charge to use tab medium on the $29 plan but I thought you need to ha...
Based on the info I have access to, it seems to be allowed with no funny buisiness going on.
I just got word that the "Unlimited Incoming" part will be removed to prevent confusion
Only to be replaced with, unlimited outgoing. 🙂
Great, thanks 🙂
