Current plan is cheaper now
  • 28 May 2015
  • 1 reply
  • 362 views
I noticed that the plan I currently have is cheaper now, and I want to change it through the self-serve centre. However, the option to select the plan with the lower rate is not available. What can I do?
Best answer by Mathieu 28 May 2015, 01:47
Hi Matt,
To access one of the new plans you are going to have to pay off your existing Tab (If any) and call up a customer service rep using *611 from your mobile phone or 1 (866) 995-6636 from a non-Koodo line. Currently, there is no way to access the new plans through self-serve.
Hope this helps!
1 reply
Hi Matt,
Hope this helps!
