Changing plan
  • 16 March 2021
  • 1 reply
  • 41 views
HI,
I’ve been trying to change my plan past couple of days but when I login my self-serve and try to change my plan, the new plan images never get loaded (just grey lines in blue boxes).  Is this just me or other people having the same issue?  I’ve tried on window laptop, iPad and Mac desktop but ending up the same result.
1 reply
Did you recently join Koodo? Also check :
Having the same problem
