changing my plan
My bill comes out the 12th of every month. I want to switch my plan but when is the best time to do it to avoid extra fees?
The best time to do it depend on which plan you have , and if yes or no you made extra usage ! But in the best case if you switch from higher plan to a lower one without extra usage it is better to change it immediately. If it is the opposite better to do it after 12th
Get it solved ! wrote:
The best time to do it depend on which plan you have , and if yes or no you made extra usage ! B...
Ack, sorry! Somehow I completely missed your answer... apologies 🙂
Your best bet is to change it a few days before the renewal, so in your case around the 10th, Erin 🙂 Yes you will be prorated for 1 or 2 days (probably no more than a dollar or two) but you'll know you are in time. Some wait till the last moment and risk being too late, which is much worse 🙂
