Changing my monthly plan
i want to change my monthly plan but i dont see how to do this anywhere out here..can someone tell me pls
Two options: You can do so by logging into your Koodo self serve, which is a link at the top of the page. OR, you can call *611 and proceed through the menu there. If either of those two paths are too complex, feel free to strut into a store and they can assist you no problem.
Userlevel 3
Not Jeff wrote:
Two options: You can do so by logging into your Koodo self serve, which is a link at the top o...
To add, if you do it through Self serve you need to go to Plans & Add-ons then select Plan from there you would need to choose your new plan from the drop down.
Here's exactly the buton you need to clic
