Canada-wide calls
Hello! I have a Koodo plan for $34 a month. Are unlimited evening and weekends calls include only local calls or Canada-wide calls as well? Thank you.
Any plan since February 2012 or so will have Canada-wide calls during all times of the day. You'll just not have to worry about airtime after 5 and on weekends, assuming you're on the currently offered $34.
So just to make sure I have this right.... If I call my sister in Calgary from nova Scotia. .. during the day will use my anytime minutes but after 5 it won't use any of my minutes..... is this right?
It depends on your plan. If your plan is Canada wide plan and includes unlimited Evenings (5pm) and weekends, Then yes. Some plans unlimited Evenings start 7pm.
Thank you! 🙂 yes my plan has both canada wide calling and 5 pm evenings 🙂 thanks so much
You're welcome 🙂
