Call display restrict does not work
I have call display restrict in my add-ons, this has been working until the past week.
Depending on your phone try going to your phone app settings and you should be able to see the setting from there too. If it also says Show Caller ID is off, then you may need to call tech support to see what's up 1-866-995-6636
Awesome - that worked. Thanks
Glad I could help ^^
