call display restrict
  • 22 October 2020
  • 2 replies
  • 1493 views
What does the “call display restrict” add on do in Koodo?
thank you
Best answer by nim4165 22 October 2020, 06:41
I think it has something to do with you being able to block your caller ID
Call Display Restrict add-on is available on the self-serve account. It blocks outgoing caller ID so my number is not displayed on the display of the receiving phone. I believe that this is a $0 add-on that can also be setup manually on the dialer (or by entering ‘67’ before  the number).
