bought a mobile friday and it was a lemon need help setting up the new one with existing info
samsung discovery touch phone
whaats wrong? it wont program for you?
If it's an Android device you should just be able to log in to your Google account when setting it up at first and check off the option to sync your old data to the new device. You can also go into settings and click on Google under accounts, then click on your email at the top of the screen and it will give you options of what you want to sync, check off what you want and then click sync.
