Best plan for hot spotting ?
  • 17 October 2020
  • 3 replies
  • 64 views
I have been using Koodo prepaid for several years now.
I am moving to the Perth, Ontario area and I need to convert to  a plan where I have enough data that I can hot spot for my job. Any recommendations ?
thanks….Derek
Depends on your budget. You can see options at https://www.koodomobile.com/rate-plans?INTCMP=KMNew_NavMenu_Shop_Plans
If you require the higher end of data usage, you may consider Telus offerings which may have high and unlimited data plans. Good luck!
DO you want to stay with prepaid or post-paid?
For hotspotting you’ll need a LOT of data. A LOT! Because your phone will essentially make your other devices think they are on WiFI, so there is no way to slow down data usage.
I think you may be best off with something like a Telus plan: currently they offer 50GB for $120.  In all other cases, I would probably advise against using your phone as a hotspot...
