best plan?
what is the best plan for a samsung galaxy ace 2 x? i just bought it today and i have the 25$ talk and text combo with call display as a add on.i need something with good data, unlimited texting and free calls in the evening and on weekends. .i cant afford to have a super expensive plan, any advice?
Available Koodo plans: https://shop.koodomobile.com/plans/plans/index.html Monthly Fee $35, $39, $50, $60, and $75
I wouldn't bother with the $75 plan with the current promotions. And if you are lucky to live in MB or SK, the $60 plan comes with 5GB of data
$25 Talk and Text combo already has Caller ID in the plan so I'm not sure why you have it as an add-on. If you want data, and unlimited calling during the weekends and evenings for a low price; the $35 and the $39 plans are good choices.
When you are out most places offer free WIFI as part of their service, so you don’t have to use up your data. This calculator might help to pick your data plan. “How much data will you need?” http://koodomobile.com/en/on/datacalculator.shtml
Yea, how much data do you require. That would help answer the question
Now my current plan is 52$ with unlimited talk in Canada plus Unlimited Text plus 1GB data. I want to go for lower plan. I don't require unlimited Canada talk and text so would you please suggest good plan
How much talk time and data do you need? If you want to keep 1GB data, it might be better to keep your plan. Koodo's current plans: $44 - 500 min, 500MB (Additional data $5/100 MB) $39 - 300 min, 300MB (Additional data $5/100 MB)
Thanks for your reply Mayumi... Please find my requirements: Data I am ok with 300MB Canada Talk I am ok with 300min so do you have any plan lesser then $39 to satisfy above requirements ?? International Text messages are free in $39 plan ?? Regards Dev Hindocha
All Koodo's plans includes unlimited text. There are the prepaid plans too. Base plan is from $15 and you can buy a "talk" and/or "Data" Booster that will allow any unused portion to carry over when you renew your base plan ( 500minutes/ $25 or 1GB / $30 are the best deal) Check this link if it suits your usage 🙂 http://koodomobile.com/en/on/plansandboosters.shtml Add: There is $34 monthly plan with 200minutes, 50MB, too. Link for the monthly plans https://shop.koodomobile.com/plans/plans/index.html
Can I expect answer now ?
Can I expect answer now ? You got your answer - $34 is the cheapest postpaid plan but it may not satisfy your data requirement. Please follow the links that Mayumi provided for more details.
