Are customers that bring an unlocked phone to Koodo eligible for the current double minutes and data plan?
If signed up under the double minutes and data, does this ever expire?
Hi there, Yes, the double minute double data does not expire until July 2. You can keep it for as long as you want. Also, if you bring in your phone, you will get 10% off monthly plan.
Erwin wrote:
Hi there, Yes, the double minute double data does not expire until July 2. You can keep it for...
To clarify: the offer expires, the plan does not. Once you have it, it's yours until you decide to change to another one.
