Any way to block US/International calling to avoid overage?
  • 14 September 2018
  • 4 replies
  • 399 views
Just switched to Koodo Postpaid from Public Mobile.
I liked the fact that i would never get charged for overage.
How can i can control this in Koodo. Is there a way to block international calling?
Best answer by Mats 14 September 2018, 16:23
Block outgoing international long distance calls
Don't want to make international long distance calls? Log in to Self Serve and remove the Pay-Per-Use International Long Distance feature from your account. It's that simple. Heads up: this doesn’t block calls to the U.S. or the Caribbean
Taken from here. It wont block US calling though.
https://www.koodomobile.com/help/long-distance-calling
Not that I know of. If you see a weird area code, just check it out before calling.
Incoming calls from that places are free also, so you can answer them at no extra cost.
Hi there...
Just to be a bit more precise, when option is removed you will still be able to make calls to any number under the North American Numbering Plan...
Google NANP for a full list of countries...
