Activate 1000 minutes of long distance calling
  • 30 July 2020
  • 1 reply
  • 40 views
What is the process for activating long distance calling?
1 reply
If you want the loig distance add-on for the country you desire you just need to login to your self serve and go to your plans and add-ons and add the add-on you want.
