$45 Plan differences
I currently have the canada-wide $45 data Plan. I never exceed the included minutes, but every now and then I'll use more dta than included in my plan. So I was looking into changing my plan to the CAN Data 1G Ultd min QC $45. I just need to understand I I'll loose anything major. I rarely make calls to anywhere that is not in quebec, but sometimes for work reason I need to call other provinces. Is the new plan going to cost me anything when calling outside Quebec? Also when comparing the plans it says I will lose unlimited incoming calls. How does it work for incoming calls, then? i get a few calls a week from my parents in Brazil on my cell phone. They call via skype, but they call me on my phone, not skype. Is that going to be charged? How much incoming call do you get? Thanks.
Best answer by Daniel Kim 12 February 2014, 05:23
That plan is canada wide so you will not have any problems calling other provinces at all! https://shop.koodomobile.com/plans/plans/index.html You will not get charged extra for calling other provinces. Also skype does not charge you any extra fees for receiving a call via skype. https://support.skype.com/en/faq/FA1214/how-much-does-it-cost-to-call-mobiles-and-landlines-from-skype The incoming calls would be unlimited actually since that plan has unlimited minutes. You won't be charged long distance for receiving a call from ANYWHERE as long as you are IN canada. Enjoy your plan 🙂
1 reply
