3gb data plan finally has more data added
thank you for finally giving more data on the 3gb plan , i now have the 4gb data with unlimited calls and texts for 75 and couldnt be more happy #koodowins always
1 reply
Just to make sure and forgive me if you know just have had some surprised. You need to switch to the new plan even though it's the same plan with just an extra GB added, it doesn't switch you automatically. You can do so in serve. If you knew that ignore my comment 😉
