Hi,
I am in a unique situation where I don’t seem to get coverage inside my home, yet my next-door neighbour has full LTE+ according to a zoomed in version of the coverage map. I have to use my Wi-Fi calling inside my home which is problematic because the only option I have for internet is satellite internet and the latency and upload are so slow that the person on the other end can’t hear me on Wi-Fi calling. This means that I have to go outside and cross the street anytime that I want to make a phone call. (I just moved to current location, used to be much closer to Halifax and did not have this problem).
Are there any planned upgrades to the TELUS/Bell LTE+ network that would see more coverage along the Eastern Shore of NS in the near future? Also, somebody suggested that I use a signal booster, but from what I read on the reviews, they work really well at amplifying an incoming signal, but not so much at outgoing, which kind of would defeat the purpose.
Best answer by Dinh
Hi
You mentioned about indoor signal. How about your outdoor signal? When you went out, did you receive better signal coverage?
Also, which phone are you using? Is your neighbor using the same phone model as yours? Different models can have different settings in display and network capacity.
Regarding the network upgrade expansion, I would suggest you check in with local Telus in your area. I think the local rep might know more about it.
