will koodo works with a panasonic home phone base
will koodo work with Panasonic home phone answering base  KX-TG4031C
It will work, but since the wireless home phone service includes voicemail you will need to either set the phone answering machine to pick up before the voicemail or ask koodo to turn the vm off if you wish to use that part of the phone.
OK how many days  does it take to  be running
If you're signing up with a new number everything should be working from the minute you get it. If you're porting in a number from a landline then there will be a delay of 2-3 business days before incoming calls start coming to the wireless home phone. Until then they will continue to come in on the landline connection. Outgoing calls will work right away.
THank you  for the quick response I will do  that
