wifi calling for Nokia 7.2
  • 7 September 2021
  • 2 replies
  • 23 views
Hi
Does anybody know how to get wifi calling supported on a Nokia 7.2.  The koodo site lists the supported devices(mine is not on the list) but I am not certain if this is the reason I cannot find how to turn wifi calling on it… Regards  G_B
That may be the reason. Other devices can get WiFi but if it won't work, you won't get assistance for it. You can try the steps on the WiFi calling feature but other than that, there isn't much that can be done.
Hi
I highly doubt your device is supported on the Koodo network. Even the Nokia 7.2 does not show up on the list on the Telus site. https://www.telus.com/en/bc/support/article/wifi-calling-explained
You can try it out, but that requires the VoLTE add-on to be enabled on your Self-Serve account. Schedule a callback through Koodo Assist to contact a Koodo rep to help set it up for you. https://Koo.do/Chat
