Why willy my battery will not charge. Charger appears to be loose. What can be done. Samsung Galaxy S2
If you very slowly and slightly push and hold the connector of the charger in a certain direction while it's in the phone does it begin to charge? If it does thentthe connection in the phone is indeed damaged and will need to be repaired. This kind of issue is not covered under warranty even if you are within the 1 year warranty period so you are responsible for the charge of the repair. You can bring it to your local kiosk and they will send it for repair.
If you very slowly and slightly push and hold the connector of the charger in a certain direction...
it starts to charge then stops charging
