why canot I connect without wifi
Best answer by Mitchell Palmater 19 January 2016, 01:02
If you're looking to browse the web without a wi-fi connection you will need a data plan.
you will also have to make sure that mobile data is turned on in your settings.
as well as make sure you don't have a data block on your account.
Cheers !
1 reply
Cheers !
