voicemail overhaul
  • 4 August 2014
  • 32 views
Why does the voicemail have to say you have reached the koodo voicemail of your number here .....thats how scammers get you how about 1604 999 999 is unavailable please leave a message and its to long i know you can make your own message but maybe you wanna be anonymous
You can change that and you can record your greeting too Here this may help http://help.koodomobile.com/plans-add-ons-data-and-other-services/calling-features/how-do-i-setup-or-check-my-voicemail
Ok but you cant change you have reach koodos voicemail ...i am saying it should only say your phone number and how you are unavailable not what company you are with yes you can make you own greeting but id rather my phone say 1604 999 9999 is unavailable please leave a message and not say im with koodo
Ok but you cant change you have reach koodos voicemail ...i am saying it should only say your pho...You can record it to say anything. I'm not sure if it you can remove "you've reached koodo's voice messaging system." Try playing around with the settings. I like my voicemail message currently, so I'm apprehensive changing things up on my own voicemail.
Ok but you cant change you have reach koodos voicemail ...i am saying it should only say your pho...If you go to record a personal greeting it does remove the openning blurb mentioning Koodo. Just access you're own voicemail and choose 4 for personal options, 3 for greeting/name options, 1 for a personal greeting and 1 again to record it. The blurb afterwards explaining the different functions cannot be disabled, but it doesn't mention Koodo at least.
Ok but you cant change you have reach koodos voicemail ...i am saying it should only say your pho...Ok ...what i am saying is koodo should re do their greeting so it just says your phone number and how you unvailable and u guys keep telling me the same thing over.....i do not want it to say what it says and i dont want to do my own greeting ok? And maybe you understand now i like the koodo greeting but hate what it says i have it on for a reason
