unlock phone to "lucky"
  • 14 October 2020
  • 2 replies
  • 113 views
Purchased a phone off marketplace and trying to unlock it so I can use my provider
Best answer by nim4165 14 October 2020, 14:10
Note that phones manufactured after 12/2017 are mostly unlocked. If the phone is locked, the mobile service provider who locked it, should be able to help you unlock with no fee (in Canada). Otherwise, you may need to do your own research and use an on-line unlocking service (probably, for a fee). Good luck!
Is it a Koodo phone are are you a Koodo customer with a Koodo sim?
