texting problem
phone shows red triangle when texting only two of my contacts text won"t go through
Best answer by Daniel Kim 17 February 2014, 01:34
Has this been happening for a while or just started recently? Try rebooting your phone and are you trying to send picture messages or just regular sms? If it is picture messages that aren't going through, make sure you have data enabled on your phone but be aware that apps can use your cellular data in the background so I would disable apps from using data before turning on data.
1 reply
