Text Messaging Problems
I have a Samsung Galaxy Ace 2, in the text messages everyones messages are going in a row and same with mine, arent they supposed to go my messages then there messages? please help.
Hi Emma, In my Samsung (which is a Galaxy Nexus) text messages are threaded like you describe, but with separate threads for each participant. If that is what you are seeing, that is normal 🙂 Or do you get something entirely different?
what do you mean? it's threaded messaging meaning everything is in one "screen" and your texts sent will be a different colour than those received,
Go to your settings, then Date and Time and make sure it's set to automatic. The check mark should be on. Everything wil be fine after this.
