TCL needs data?
  • 14 June 2021
  • 3 replies
  • 29 views
Hi,
I got a certified TCL 10 less than month ago. Whenever I receive MSM, I had to turn my data on to read those messages. Is there any other way I can receive and read messages without turning my data on? I have limited data plan and don't want to exceed data usage.
Best answer by Mayumi 14 June 2021, 15:29
Yes. You need to turn your data on to receive a picture message(MMS).
What plan do you have? Sending and receiving MMS doesn't use much of data.
If you can access WIFI easily, you can use some apps like messanger, WhatsApp...etc  to receive pictures too.
Hi,
Thanks for your response.
I only have 2GB data on my plan. I will always be around wi fi, so I try to use as much I can.
I'll try "WhatsApp" as you suggested. Are there any good apps you'd recommend?
Hi,
Its depends on what your friends and family members are using too.
 My parents (in Japan) have "Messenger", so I use it when I call/video chat with them.  Most of my Japanese friends use "Line", so I use it with them ...
