Switching Phones
  • 9 September 2020
  • 4 replies
  • 164 views
How do I register my new koodo phone and sim card using my existing koodo phone number?
You are better off using your old SIM with your new phone (no other action needed) and keep the new SIM as a spare.  If you use the new sim card, which already comes activated, your old sim card will stop working (deactivated) after 90 days.
How do i go About switching if im on bell network
Ideally you'd port in store to walk out with an operating Sim, but covid and Koodo charges 40 bucks for that. So You should create a new Koodo line online, once you get the Sim in the mail and get the Sim activated, register for self-serve and then select “move my number”to port your bell number over.
You can either order a sim card online, and then once it arrives port the number over here: https://www.koodomobile.com/en/help/moving-your-number-koodo
Or you can visit a store and pick up the sim and port the number all at once.
