Sound loss
I keep losing the sound on my Galaxy Ace II. Last time a fellow at the KOODO booth opened the back and removed the chip. Sound was ok again after he replaced the chip. Now it's gone again. What gives?
Best answer by Daniel Gunn 4 September 2014, 15:28
Hi Ron, What it sounds like the issue you're having is a hardware problem. How long have you had the device? If it is under a year you can bring it to the nearest Koodo kiosk and have it serviced. If it is older than a year you can try removing the battery again and sim card and putting them back in but it will only be a minor fix. The Ace 2X has been known to be plagued with issues, so you can try the options I mentioned or you can possibly upgrade to a newer device that may be better suited to your needs. Hope that helps.
1 reply
