Snowbird going to Arizona for 5 mths ??.
Have a Lumia 520...Microsoft. What can I do to have reasonable service and cost in the USA with access to Canada
I'd recommend you put a Seasonal Hold on your Canadian account - 10$/mos. Then get your phone unlocked--> CellUnlocker.net Then get a local pre-paid SIM from T-Mobile when you're in Arizona.
John Burke wrote:
I'd recommend you put a Seasonal Hold on your Canadian account - 10$/mos. Then get your phone un...
Just to add, if you put your account on Seasonal Hold, upon your return you can only choose a plan that's currently offered by Koodo. If you're on a promo plan from before, you won't be able to get it again.
Another option is: if you live in an area with Wind Mobile coverage, and you are planning to travel frequently to US, switch to Wind Mobile. You can then use your Canadian phone number in US at very reasonable rates: 20 cents/min or $10/month unlimited!
