Samsung Galaxy Ace 2x GT-S7560M Problems with MMS
How can MMS be downloaded via wifi connections? I do not have data but have MMS as part of my phone plan, and am unable to send/receive any picture messages (It says downloading until it errors with no useful information).
You can't download MMS in any way other than a cellular data connection. What you could always do is while connected via wifi (so that your apps don't use the cellular connection) re-enable your cellular data to get your MMS messages. Keep in mind if any apps use the cellular connection you are responsible for their data usage.
Jordan, does this mean that you cannot download the MMS unless data is activated on the phone?
Yes that is correct.
